Severe lags with CREO Parametric due to Desktop Window Manager process high CPU
- 5 replies
- 3918 views
- Translate All
I have installed CREO Parametric version 11.0.0.0.0 on my Lenovo Thinkpad P53s on Windows 10 and I am experiencing a severe performance issue (I had the same problem with version 9.0.0.0 by the way)
Characteristics of my Laptop :
- Operating System : Windows 10 Pro version 22H2
- Processor : Intel(R) Core(TM) i7-8665U CPU @ 1.90GHz 2.11 GHz
- Installed RAM : 48.0 GB (47.7 GB usable)
- GPU 0 : Intel UHD Graphics 620
- GPU 1 : NVIDIA Quadro P520 GPU1
Problem Description :
When moving a model on the screen or simply opening menus in CREO application, the graphic suddenly freezes for one or two seconds, making the work really annoying. After a while, all seems to be normal, until it restart to lag.
Analysis :
- At first, I thougt iwas a problem with the NVIDIA GPU 1 settings. I specified all CREO processes as allowed to use the PGU 1. Also, I enabled Hardware Acceleration under Windows "Graphic Settings". It did not solve the problem.
- Then, I removed CREO from the list of applications using the NVIDIA GPU and disabled completely NVIDIA in the Windows Device Manager, with the objective to only use the native GPU 0 of my laptop. Unfortunately, it did not solve the problem
- Then, I figured out that the "Desktop Window Manager" process is probably the cause of the problem. When making fast moves of the 3D model, I can see that the Desktop Window Manager process suddenly consumes a lot of GPU 0 , sometimes reaching 100% utilization !
- With other graphic applications, I don't have the problem though
Of course, I made sure that that my Windows 10 is at the latest level. I searched on the internet for similar problem descriptions but unfortunately without success.
Can anybody help me ? It would be more than appreciated
Yves
