Simulate: issue with measure on component interface for measuring shear
SB_10895015
2-Explorer
I am using Creo Simulate Release 7.0 and Datecode7.0.3.0
I'm having an issue adding a measure. I have a pair of nested cones that represent the front of an aerodynamic body. There is a pressure applied to the outside of the outer cone. There is a bonded interface between the two cones. So, this is like a cone with a thin coating of a different material.
I want to know if the coating will delaminate. I want to put a measure on a line along the inner surface of the cone so I can measure shear. However, I can't figure out how to get shear in a specific axis (not one of the primary axes), and whenever I add a measure to a line the study will no longer run.
3 REPLIES 3
Hi @SB_10895015
Would it be possible for you to share the file with us?
Amol Lungare
Potentially. I will need to get permission. I will check tomorrow and see.
-S
Please find, attached, the file. This includes the Simulate components.
Note: the measure "interface_shear"
Along that line, I want to generate a plot of shear in-plane with the surface of the inner cone.
Since the original post, I managed to get the model to run with this measure in place, by changing the mesh rules.
I still don't know how to get the shear in-plane.
