Small window to edit value opens and closes immediately in sketch module of 3D part
NB_10462420
7-Bedrock
I am using Creo Parametric Release 7.0 and Datecode7.0.8.0
Since today, in the sketch module of 3D part, when I want to edit a value, the window to edit opens and closes immediately.
I tried to restart my station, create a new part and change the CREO version but this problem persists.
I had a problem with my config file. In order to locate the problem, I suppressed my file and I restart the software. After, I opened this file and I suppressed paragraph step by step to find which one had a problem.
What was the config setting that caused the problem, mine has just started doing this but the config.pro file hasn't changed in weeks.
Dario73
(To:NB_10462420)
To solve the issue, you can insert this option in config.pro:
web_browser_homepage about:blank
This is a problem that PTC fixed with Creo Parametric 8.0.8.0 and 9.0.4.0
https://www.ptc.com/en/support/article/CS378868
