Summary - Creo 1.0 M030 won't run
Aha, we have a winner. It was the PSF files. We have two license
configurations but instead of entering in the info to create the PSF
files at install time on each machine, I keep a copy of the PSF & BAT
files on the server and copy them into the bin folder after install,
removing the default PSF & BAT. The PSF files contain the ship code:
SHIPCODE=M030
CREO_COMMON_FILES=Common Files\M030
The PSF files I have on disk were from F000, so they did not work with
M030 on the laptop. On my machine, I had installed F000 and upgraded to
M030 and the PSF files got revised when I upgraded. When I copied the
F000 PSF files on disk into my Creo 1.0 M030 bin folder, I got the same
result that I had on the laptop, Creo wouldn't launch. When I put the
M030 files back, everything worked again.
So now I get to keep a set of PSF files for each new build. Yay.
Doug Schaefer
SHIPCODE=M030
Doug Schaefer
