I am using Creo Parametric Release 6.0 and Datecode6.0.0.0
There is no permission to use [Copy Geometry], the command button is gray and cannot be used. I hope you can help to confirm whether our current license includes this function command.
Translated the text from Simplified Chinese to English using google translate on 19-April-2023 at 11:46am IST. Translated by vnamboodheri.
Subject: 没有权限用【复制几何】,希望您帮忙确认下当前我们的许可是否包含此功
Body: 没有权限用【复制几何】,命令按钮是灰色的,无法使用,希望您帮忙确认下当前我们的许可是否包含此功能命令。
Hi @晓宋_10170248
This is a license related issue. Copy geometry, needs advance license of assembly.
Refer https://www.ptc.com/en/support/article/cs28079
I hope this will help.
Hi @晓宋_10170248
