UDF's
TracyWillis
UDF's
Can someone please tell me how to insert a UDF? In my Model Tab > under the Operations Dropdown menu the UDF Operations are grayed out.
My config pro_group_dir is set at the SUP level and it is set to a location that I can read from. I've also verified that the (*.gph) files are in the folder.
What else could be the snag?
Creo Parametric 2.0 m40
Any help will greatly appreciated - Thank you all
Tw
Wow! - How could I miss that. Found it in the Get data group.. Thanks everyone
