Using Locked License but want to see PTCSTATUS of server
akelly
I have a node-locked license of Pro/E, but the majority of our license are floating. Occasionally, I need to see who is using Pro/E. Because I am running a node-locked license, PTCSTATUS only reports my node-locked license. My work-around is to log in to the server with remote desktop to run PTCSTATUS.
Kind of slow. Kind of annoying.
Is there a way for me to see PTCSTATUS of the floating license server without using remote desktop?
Using Wildfire 4.
Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics | +1 440 326 5555 | F: +1 440 284 1090
lwh
(To:akelly)
Simple: make a copy of the ptcstatus.bat script, e.g. to my documents and replace the servers in the line "set PTC_D_LICENSE_FILE=" with the names You want to check.This may include machines with locked licenses, but they will not give information about whether currently used or not.
