The following error is thrown when creo connection string is accessed from web browser.
Retrieving the COM class factory for component with CLSID {456E0110-2031-3907-AFE5-9201C97A915E} failed due to the following error: 80070005 Access is denied. (Exception from HRESULT: 0x80070005 (E_ACCESSDENIED)).
An aspx page is developed and the following code is added. but it throws the above mentioned error.
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
Dim asyncConnection As IpfcAsyncConnection = Nothing
Dim cAC As CCpfcAsyncConnection
Dim session As IpfcBaseSession
Dim exePath = "D:\Program Files\PTC\Creo 2.0 M020\Creo 2.0\Parametric\bin\parametric.exe"
Try
'First Argument : The path to the Creo Parametric executable along with
' Command() line options. -i and -g flags make Creo Parametric run in
' non-graphic, 'non-interactive mode.
'Second Argument: String path to menu and message files.
cAC = New CCpfcAsyncConnection
asyncConnection = cAC.Start(exePath + "-g:no_graphics -i:rpc_input", ".")
'asyncConnection = (New CCpfcAsyncConnection).Connect(Nothing, Nothing, Nothing, Nothing)
session = asyncConnection.Session
Label1.Text = "Success"
Catch ex As Exception
Label1.Text = ex.Message
End Try
End Sub
Sometimes creo session is not getting connected with argument as Nothing. Try following code snippet and let me know your results:
Try
_objIpfcConnection = objCCpfcConnection.Connect(Nothing, Nothing, Nothing, Nothing)
Catch
Try
_objIpfcConnection = objCCpfcConnection.Connect(DBNull.Value, DBNull.Value, DBNull.Value, DBNull.Value)
Catch
End Try
End Try
Regards
Ketan
Hi Ketan,
how to declare the objCCpfcConnection and _objIpfcConnection
dim _objIpfcConnection As IpfcAsyncConnection
dim objCCpfcConnection As New CCpfcAsyncConnection
With this declaration, you should be able to get session object.
One assumption is that creo should be open while accessing session with above method. You can do below to start creo:
dim processcreo As Process = New Process()
Dim startInfo As New ProcessStartInfo
startInfo.WorkingDirectory() = 'Set your creo working directory path'
startInfo.FileName = 'Set creo's exe file path
Process.Start(startInfo) 'starts creo
Thread.Sleep(15000) 'waits for 15 seconds: increase this timing if your code need to be worked on system having less RAM
Hope this will work for you.
Regards
Ketan
I am getting the following error.
pfcExceptions::XToolkitGeneralError
on which line?
This is error code thrown...
i was able to launch as windows application but unable to launch through web browser. do you have guide to setup the web based server
