VBAPI update mass properties
ttiainen
2-Explorer
I am using Python/Win32com to automate Creo 3.0 models.
Basically I am trying to set a parameter through the VBAPI, regenerate the model, and then read the mass properties (updated surface area and volume)
I can now get the model to update and regenerate but for some reason the mass properties do not update! So even if I regenerate the part to be 10 times bigger, the mass properties dont change. If I change the parameters manually, the mass properties change too.
I have set the configuration option mass_property_calculate to automatic with no results.
Is there some trick in the VBAPI or some configuration option I could use to solve the problem?
0 REPLIES 0
