Hello everybody.
I have already completed a drawing with views, dimensions, tolerances, annotations ...
Now I'd like to add the view names to all existing views.
I modified the config option
make_proj_view_notes = yes
but the names are not added.
1 - Is it valid only for new Views ?
2 - Is it valid only for new drawings ?
3 - Is it possible to obtain the view names on existing drawing views ?
4 - Is it possible to customized the view name ? Instead to have the format "View Top1-Top1" I need to write only view name "Top1" .
Thanks in advance
Pierluigi
There are some view properties operations that will add the view name to an existing view.
Maybe you can utilize one of those with a mapkey to get the view name to show up on existing views.
Try changing a projection view to a general view (apply the change) then change back to a projection view. It will add the view name if you have the option turned on. Maybe you can find a way to incorporate a similar change like that in to a mapkey that will make the drawing updates much quicker.
Are you using the "=" sign in the config file? Don't do that.
Check to see there isn't a config.sup file that overrides the setting.
Hi , for sure the config option is correctly written, without "=".
Anyway it doesn't work !
This option has been set on config.sup.
Pierluigi
I wouldn't add that option to the config.sup. That makes it non-overidable. Maybe that is what you want but seems like it should just be a standard config.pro option you would include in your default config.pro and then if a user needed to create a drawing without view names, they could turn it off temporarily or as needed.
I just tested it. It takes seconds to test.
I started without the option. New drawing. Made 3 views. No view names.
I added the option set to yes.
No view names were added.
I made new view. View names were added to the newly created views.
In the drawing setup, you can control auxilary view names but I don't see an option to control other types of view's names. (option aux_view_note_format)
Yes
the point is that it's not possible to keep all views already defined and add the names.
Consider several drawings, each of them with several views full of dimensions, tolerance, symbols,...
I'm afraid I'll have to re-create everything !
Pierluigi
It would be very bad for existing drawings to be affected by a user's config options. If someone had manually created the names under the views and later a user turned on a naming system, then they would overlap, potentially being unreadable.
I completely agree BUT the customer WANTS to convert all drawings in their standard and format
SO WE HAVE to modify all documents already released with this new view layout including the view name !!
Contact PTC with a requirements document and see what they will charge to develop a program to fulfill this need.
Also, it works best to state your actual requirement up front and not after everyone else has beat their heads against a vague description of the problem.
That's a good compromise.
It's a manual operation but it allow us to save the work already done (view, dimensions, ...)
Thanks again.
Pierluigi
Automation. This would be pretty simple with something like SmartAssembly. I imagine you could use J-Link or Visual Basic as well.
Hi
we're going to install and to use SmartAssembly just in next weeks.
I'll test it !
Pierluigi
1) Config.pro options do not change existing views, only new views added after the option is set.
2) New or old drawings, it is for views on any drawing.
3) They should be stored with the view, but not sure how to display them.
4) Yes, modify the name format.
