WF5 Publishing With CreoView2
On our test server I have managed to install WF5 and the CreoView2 Adapters. However, when I manually publish an assembly from PDMLink, the action fails. WF5 tries to load the assembly but doesn't appear to load any of the sub-tier components.
Do I need to register a server with WF, like I would in an interactive session of ProE? Or is there some other configuration step that I missed?
I've gone through the Adapter guides a couple of times now but haven't found a solution. If someone could point out the error of my ways I would be most grateful.
Steve
