When save drawing as dwg file ,get the error message "c++ library runtime error, R6034".
cmy
When I save drawing as dwg file ,get the error message "c++ library runtime error, R6034".
If I save drawing as dxf file, it works fine, this issue is not file specific issue, it will happen on all dwg file.
I am using Creo 2.0 m180 on windows 7 x64 pro.
How to resolve this issue?
0 REPLIES 0
