assembly start-up conflicts
mathew.palazola
2-Explorer
I get this "conflicts" message everytime I try to start this assembly.
I don't know what "cannot be propagated to..." means.
What I would like is, maybe, a config option to turn the stupid messages off or bypass it altogether.
Any suggestions?
I assume you actually mean "save this assembly" instead of "start this assembly"
It looks like this assembly has designated parameters that are not defined in Windchill. Simply undesignate these parameters. A "designated" parameter expects to have a corresponding Windchill parameter that will be changed when you modify the parameter in Pro/Engineer or the opposite (change param
value in Windchill changes value in Pro/Engineer).
> Any suggestions?
> Attachment Links: assy-startup-conflicts 0821-1.jpg (132 k) <">http://portal.ptcuser.org/p/fo/do/download=1&fid=16259>
> Site Links: View post online <">http://portal.ptcuser.org/p/fo/st/post=110921&anc=p110921#p110921> View mailing list online <">http://portal.ptcuser.org/p/fo/si/topic=3> Send new post via email <">mailtoSmiley Tongue-> Unsubscribe from this mailing list
> <">mailtoSmiley Tongue-?Subject=Unsubscribe> Manage your subscription
