"Carlos Diaz" wrote:
what i want to do is to setup a config.sup on the network so i can have all users seeing the same config.sup file and if a change is made, it only needs to be made to the .sup file on the network and after the new pro launch the user will have the latest and greatest. my question is where do i set the search path for pro to look for the config.sup file on the network? side note: we have pro installed local on all our machines, so putting a config.sup file on a local hard drive in the loadpoint/text directory does nothing for the other users, unless i copy n paste the same config.sup file into all the machines but that makes it a pain when we make changes to the .sup file since we will have to copy and paste the changes into all the machines so they all see the latest and greatest config.sup file. thanks guys Carlos Diaz
