jlink and Drawing Symbols
AndreasVogt
I'm not an expert in JAVA, but I try to understand the examples of the jlink-doc in Pro/E Wildfire 4. So I made some menu-modifications and got a script to modify some config-options working.
Now I try to put a drawing-symbol on the drawing. There ist an example in folder proE/jlink/jlink_appls/jlinkexamples: pfcDrawingExamples.java with the function: placeInst()
FUNCTION : placeSymInst()
PURPOSE : Place a CG symbol with no leaders at a specified location
public static void placeInst() throws com.ptc.cipjava.jxthrowable
Get the current drawing
Session session = pfcGlobal.GetProESession ();
Model model = session.GetCurrentModel();
if (model.GetType() != ModelType.MDL_DRAWING)
throw new RuntimeException ("Current model is not a drawing");
Drawing drawing = (Drawing) model;
Retrieve the symbol definition from the system
DetailSymbolDefItem symDef =
drawing.RetrieveSymbolDefinition ("CG", null, null, null); //<-- ErrorObject on second run!
Select the locations for the symbol
boolean stop = false;
Point3Ds points = Point3Ds.create ();
while (!stop)
MouseStatus mouse = session.UIGetNextMousePick (null);
if (mouse.GetSelectedButton() ==
MouseButton.MOUSE_BTN_LEFT)
points.insert (0, mouse.GetPosition());
else
stop = true;
Allocate the symbol instance decription
DetailSymbolInstInstructions instrs =
pfcDetail.DetailSymbolInstInstructions_Create (symDef);
for (int i = 0; i < points.getarraysize(); i++)
Set the location of the note text
FreeAttachment position =
pfcDetail.FreeAttachment_Create (points.get (i));
Set the attachment structure
DetailLeaders allAttachments =
pfcDetail.DetailLeaders_Create ();
allAttachments.SetItemAttachment (position);
instrs.SetInstAttachment (allAttachments);
Create and display the symbol
DetailSymbolInstItem symInst =
(DetailSymbolInstItem) drawing.CreateDetailItem (instrs);
symInst.Show();
I modified the script to get a symbol out of the symboldirectory and it works - but only once! I think, because the symbol is in the drawing yet. On the second run of the script with the same drawing there ist the following exception with RetrieveSymbolDefinition: com.ptc.pfc.Implementation.pfcExceptions$XToolkitFound
I have tried to modify the errorline to
drawing.RetrieveSymbolDefinition ("CG", null, null, true);
but when eclipse says
The method RetrieveSymbolDefinition(String, String, Integer, Boolean) in the type DetailItemOwner is not applicable for the arguments (String, String, null, boolean)
Has anybody an idea to get the script working again and again?
Thanks.
Andreas Vogt
6 REPLIES 6
Andreas,
when the symbol definition already is on the drawing you must find it as a
modelitem of type ITEM_DTL_SYM_DEFINITION.
Use something like:
drawing.GetItemByName(ModelItemType.ITEM_DTL_SYM_DEFINITION, "CG");
Good luck
Bjarne Frandsen
"Andreas Vogt" <a.vogt@ibb-konstruktion.de>
16-04-2009 11:19
Please respond to
To
cc
Subject
[proecus] - jlink and Drawing Symbols
while (!stop)
else
stop = true;
symInst.Show();
Thanks.
Andreas Vogt
-----End Original Message-----
thank you for your support. But it don't work, because the DetailItem has no name! I think it should work with DetailSymbolDefItem DetailSymbolDefInstructions and GetInstructions - but I don't now how...
cu
Andreas Vogt
Andreas,
try drawing.ListItems(ModelItemType.ITEM_DTL_SYM_DEFINITION);
/Bjarne
17-04-2009 10:17
Please respond to
To
cc
Subject
[proecus] - RE: jlink and Drawing Symbols
cu
Andreas Vogt
hi,
the DetailItems-List write down in an HTML-Sheet looks like this:
<h2>item.GetName() null</h2>
Index 0 item.GetId() 0 item.getClass().getSimpleName(); DetailSymbolDefItem
Index 1 item.GetId() 0 item.getClass().getSimpleName(); DetailSymbolInstItem
How can i get touch to the DetailSymbolDefItem with the item-list?
Andreas
You need to cast the ModelItem to DetailSymbolDefItem:
DetailSymbolDefItem dsdi = (DetailSymbolDefItem)item;
/Bjarne
17-04-2009 11:28
Please respond to
To
cc
Subject
hi,
item.GetName() null
DetailSymbolDefItem
item.GetName() null
Andreas
hi again,
that's it! 🙂 Great, thank you!
With dsdi.GetInstructions().GetName() you get the Name of the symbol.
cu
Andreas
