number of info lines in main window
mathew.palazola
2-Explorer
Is there a config.pro option for setting the number of lines for the information output area (dashboard?) of the main winow?
It comes up with 4 visible lines, but I always drag it taller so I can see 6 or 8 lines.
thanks
6 REPLIES 6
visible_message_lines <#>
If you do a right click in that area, you can open the whole info data message log.
Enjoy,
Ronnie Shand
Used it.... doesn't do anything
I’ve had the same frustration. I always get 2, no matter the config setting. And, many messages require 3 lines.
Doug Schaefer
LinkedIn
Hmmm... strange, it's always worked for me.... Currently, I have it set to 3, and I see 3 lines plus 1... This is in wf4, M140... I also have my config.win setting to show the "dashboard" on top...
Does not work for me either. My config was set for 4 which I have, but I changed it to others higher and lower tried it and it made no difference. Strange…..maybe config.win overrides it but I did not check into that nor do I care that much so I am done thinking about it.
