protk.dat problem
pmichalski
2-Explorer
protk.dat problem
I have problem with one workstation. With Pro/e should start Matrix1. I
have protk.dat file with all inforamtion and start script which calls
for that file. Problem is that Matrix generally starts but from time to
time does not. When Matrix does not start Ansys, which is calles to
start by other dat file, does not start as well. Restart do not solve
issue. When applications do not start I always try to start them
manually (Tools/Auxiliary Applications) no positive result (both do not
start). When I try to start dat files manually and then restart most of
times helps and Matrix and Ansys starts. I have same configs on about 20
other workstations and no issues.
Workstation DELL Precision 670
OS WINXP SP3
Pro/E Wf2 M280
Do any of You have similar problem and know solution?
Thanks in advance
Best regards
Przemek
0 REPLIES 0
