I am using Creo Parametric Release 9.0 and Datecode9.0.0.0
creo dopo un errore irreversibile non riapre più i file.
senza il caricamento delle nostre impostazioni i file si aprono.
Here are the errors that I faced
impossibile aprire i file
creo after a fatal error no longer reopens files.
without loading our settings the files open.
unable to open files
Translated by Iuliana Lazar with Google Translate on 09 Dec 2022
You need to go thru your settings to understand which setting is causing this.
Make a copy of your config.
I usually take half of my config.pro and delete it, If the problem is still there, it is in that half, if it is not there, it was in the deleted half.
Keep taking half of your config.pro out until you narrow it down to the problem setting.
