Assign test cases to test session
MT_12222862
I am new in RV&S. My goal is to assign test cases to a test session by using the GUI. When I try this via drag&drop I am facing this issue:
What are the prerequisites to add test cases into a test session? Thanks.
Best regards,
Tahir
aseifert
(To:MT_12222862)
Hi Tahir,
it depends on where you drop the cases onto at the session item.
As per the error it seems there is no relationship configured to hold the cases which may point to a misconfiguration.
I would suggest opening a support case for analysis.
Note: Besides D&D you should be able to add Test Cases to the "Tests" relationship field.
aseifert
(To:MT_12222862)
Hi Tahir,
