The content you are trying to access is permanently deleted.
We are using Integrity Client 11.0.0.506
Currently the project checkpoint numbers in the Project History are 1.2, 1.3, ..., 1.1206
Can the project checkpoint number be set to 2.0 ?
Hi amatei,
FYI, I can't seem to access the .png file you attached? Not sure why.
But to answer your question, you can't specifically set the checkpoint number in the manner you want.
See this:
https://www.ptc.com/en/support/article?n=CS83562
Hi amatei,
See this:
It seems that the Checkpoint.png file that I have attached can be downloaded but cannot be previewed
