We are using Integrity Client 11.0.0.506
Currently the project checkpoint numbers in the Project History are 1.2, 1.3, ..., 1.1206
Can the project checkpoint number be set to 2.0 ?
Hi amatei,
FYI, I can't seem to access the .png file you attached? Not sure why.
But to answer your question, you can't specifically set the checkpoint number in the manner you want.
See this:
https://www.ptc.com/en/support/article?n=CS83562
Hi amatei,
See this:
It seems that the Checkpoint.png file that I have attached can be downloaded but cannot be previewed
