How to use Computation field (xyz) in "Item Field Trend" Type Chart of Style Vertical Stacked Bar.
I have Computation field (xyz) which gives me count of Requirement/Document (Content/Segement) modified by particular User.
I have Query which gives me all users, also I have query which gives me Requirement/Document (Content/Segement) modified recently.
We required the attached graph.
take look at this older Post
"plot any trend chart in report"
The main problem in integrity is the limitation that you cannot JOIN queries to perfrom complex analysis.
The workaround is a report where you can run several queries and computations until you have fetched all data you need and than perform a custom Visualisation.
It the same apporach a BI - tool like BIRT or JASPER would use.
