Exclude Folder (Subproject) from si viewsandbox
PaulLi
2-Explorer
I'm trying to compare a local sandbox with the server to find out if anything has changed or new files were checked in that differ from my local data.
I do this by using the cli command: si viewsandbox –S <sandbox_path> --recurse –filter=changed:sync –filterSubs
and now want to exclude a folder from this request.
So to say if anything was checked in on the server in the Folder "IgnoredFolder" or any subfolder of it, I don't want the command to return this files as changed.
I already tried by adding the option --filter=!file:IgnoredFolder, --filter=!file:*IgnoredFolder and a lot of other combinations but didn't get a result without the IgnoredFolder.
The same happens to me if I try to create a scoped Sandbox with the option --scope=!path:IgnoredFolder
Could you give me a hint what I got wrong here or how I can achieve what I want?
2 REPLIES 2
awalsh
(To:PaulLi)
Have you tried adding the wildcard at the end of the folder name, that is *IgnoredFolder/* I've tested the commands below on my own client and they are correctly filtering the sandbox.
For members in a subdirectory, but not a subproject, you can use the file filter for viewsandbox.
si viewsandbox -S <sandbox_path> --recurse --filter=changed:sync --filter=file:*IgnoredFolder/* --filtersubs
Members in a subproject are not filtered because the name of the member does not contain the folder name. In this case you need a scoped sandbox.
si configuresandbox -S <sandbox_path> --scope=!path:*IgnoredFolder/*
When viewing the scoped sandbox, use the --filtersubs option to filter out the subproject(s) that are out of scope.
si viewsandbox -S <sandbox_path> --recurse --filter=changed:sync --filtersubs
kthierer
(To:PaulLi)
My approach would be multiple steps like
si print -R --revision=:member --fields=membername --noheaderformat --notrailerformat > members.txt
REM filter members.txt eg. with findstr or grep
si viewsandbox --selectionfile=members_filtered.txt
However one sideffect of using ----selectionfile is that the subproject/subsandbox information
is not displayed anmore.
HTH Juergen
