FlexNet License Server Install problems
jwangpeng
7-Bedrock
Hello ereryone:
     I have install the FlexNet License Server on my computer but has failed.
      OS : Windows Server 2012 R2  64bit
     JDK:jdk1.8.0_101 & jre-7u65
     the error message is :ZeroGu6: Windows DLL failed to load .....
     dose anybody konws the reasons of the problms?
     I need your help.
     thanks & best Regards.
What version of Integrity are you using?
Yes, usually compatiblity mode is required, but you will probably have to install an older version of Flex as well (or run a Flex instance on another non Windows Server 2012 machine.  As mentioned, the Flex version, that comes with Integrity, seems to have issues with supporting Windows Server 2012.
See this knowledge article which covers this:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS176069
4 REPLIES 4
Hi jiang jason,
You need to run the installer in compatibility mode.
The FlexNet Version that comes with Integrity doesn't support Windows 2012 R2.
Dominik
Hello Dominik:
     Thanks all the same , i have try it again as you says ,but the problems still exist.
Jason
Hello Michael Chatel:
     Thanks for you help.
     My Integrity's version is 10.8,and the Flext is comes with the integrity install package,it's version is 12,5,0,0 ,but i also want to know whether  there is another way that we can solve the problems?
Best Regards.
jason
