Hostname change results in error in MSSQL database connection with PTC RV&S appplication
AarushiS
I have installed MSSQL Server and PTC RV&S client and Admin in a virtual machine. Now the machine's hostname has been changed and have done below remediation-
  • Got new license from PTC
  • Changed is.properties files by replacing old hostname with new one.
  • Changed the hostname in SQL server management studio with a query.
  • Have checked the TCP/IP port as well.
  • Executed the Telnet to the new hostname and sql port - working
what all steps do I need to follow to remediate the issue and avoid the error. Also is there any need to install the application again as well?
Hi @AarushiS
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Catalina
PTC Community Moderator
PTC
