I do test using command line Interface.
si sharesubproject --hostname=%HOSTNAME% --port=%PORT% --user=%USER% --password=%PASSWORD% --cpid=%CP_ID% --project=/Target_project/project.pj --sharedProject=/Source_Sharedproject/project.pj --subprojectRevision=1.25 --type=build /Target_project/Source_Sharedproject/project.pj
"Source_Sharedproject" project is managing configuration through 'label'. (for example, 1.25 = ABC_function_bugfix-1.2.1)
So, my co-work and I want to use this CLI by using options label= 'ABC_function_bugfix-1.2.1' but I could not find those option in a help document.
Doesn't CLI 'si sharesubproject' have a option for labels indeed?
Just an idea
si viewprojecthistory --project=/Source_Sharedproject/project.pj --rfilter=labeled:ABC_function_bugfix-1.2.1 --fields=revision,labels > tmpPjHistorySearch.txt
si projectinfo --project=/Source_Sharedproject/project.pj --projectRevision=ABC_function_bugfix-1.2.1 > tmpPjInfo.txt
Parse tmpPjHistorySearch.txt or tmpPjInfo.txt for the found project revision and build your 'si sharesubproject' command.
Hi, thank you for your reply.
I develop CLI using batch. So do you know how can I get revision from tmpPjHistorySearch.txt?
I try your ideal and I don't have ideal how I can get 1.25 from this printed form. ㅠㅠ![]()
1.25 ABC_function_bugfix-1.2.1
For me (using Intergity 10.4) I discovered something that is not documented directly in the reference for 'si sharesubproject':
--subprojectRevision can point to a label
Maybe there is a hint for this somewhere else in the reference guide.
si sharesubproject --hostname=%HOSTNAME% --port=%PORT% --user=%USER% --password=%PASSWORD% --cpid=%CP_ID% --project=/Target_project/project.pj --sharedProject=/Source_Sharedproject/project.pj --subprojectRevision=ABC_function_bugfix-1.2.1 --type=build /Target_project/Source_Sharedproject/project.pj
The internal logic for for this must be something like:
If subprojectRevision does not resemble a project revision number then it is a label and the command shall search the revision number by label.
Of course if you move that label you should not expect that your existing shares will follow ![]()
You would have to use "si configuresubproject" for that.
Regards Jürgen
