How do I change the version of a project or sandbox file to 2.0?
DK_10831057
6-Contributor
The current version is 1.xx, but I want to change the version to 2.0 and 3.0 What's the method?
Example: Checkpoint
ssaul
(To:anursingh)
I think @DK_10831057 wants to set a project revision to something higher than 1.xx.
The project revision is set on a checkpoint or snapshot.
As far as I know, other than for a member, it is not possible to do this - it is done automatically on a checkpoint or snapshot.
When checking in a member, it is possible (with some restrictions) to set the member revision to 2.xx or something else.
2 REPLIES 2
Hi DK_10831057,
Welcome to the PTC Community!
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Anurag
ssaul
(To:anursingh)
