Hello All,
The problem is that if we have customer requirements (RQ1) which we aggre and derive internal requirements (RQ2) from it, than this requirements could be also a"customer requirements" for our supplier (They are the sub-supplier for the main Customer) which slhall be tracked and documented what the different suppliers agreed what not, but actually we can document the discussions and agreemnets only on our customer side (RQ1) level and not possible to do it on RQ2 level where our requirements are defined to our supplier.
Is there any general way, what Integrity tool propose to use for managing sub-supplier requirements agreements, discusioons, deviation lists?
BR,
János
Hello Janos,
You should probably get in touch with a PTC account manager. There are a number of potential ways to chain those requirements, but an implementation specialist would have a better idea of how to do this.
Kael
Hello Janos,
Kael
Any recommendations on implementation specialists to contact from PTC for Project link used for supplier early design involvment?
Hello Aleksandra Volkanovska,
I actually recommend you go through a Sales Account Manager, since they're the ones who have the networks to contact implementation specialists.
Kael
