How to change the target path of an imported PTC document in Integrity Requirements Connector tool
EM_10182014
Version: Windchill 11.2
Use Case: I have imported from PTC to DOORS a document, which I selected the target path wrong in the IRC 3.4 tool
Description:
If I try to change the target path in DOORS, IRC doesn't allow me to do it, it doesn't list the document to select another target path. Check the attached files from the IRC tool.
How can I change the target path of an already imported PTC document in DOORS?
Take a look:
EM_10182014
(To:VladimirN)
Hello Vladimir,
Thanks for the information and sorry for the delay to response. I had some issues with the IRC license. I followed the instructions from the second bullet (Modifying DOORS import options", however I am getting an error when clicking on the Target Path as you can see in the following image:
Do you know if I could be missing something? I am just trying to change the Target Path of a document that I had previously imported (using other roundtrip). Now, in a new roundtrip I have such document (which appears with the update operation as it was imported previously) which I need to update but need to put it in a different path.
Edgar
Here are other imported documents, those are not showing a Target Path:
But if I try to specify one, It does not allow me to do it, the Finish button is grayed out>
Hi @EM_10182014,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
Anurag
