Hello Team,
I need help with MKS Implementer, PTC Inc.
The issue I have is with physical and logical files.
When I make changes to a file and promote it, the new objects do not have the same object authority as I had given manually.
So, every time I make changes to the object, I have to go to all the machines/environments and change the authorities.
Hi @MN_12056425,
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Anurag
