Hello team,
I have created some custom MS Word reports and seems like their definitions are tied to the client side only.
Is there a way to distribute them to clients at once? Of course I can create a custom service pack bundle that holds these reports but may be other ways exist?
Hi @AN_10548594,
Thank you for your question!
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Best regards,
Hello Andranik,
I assume you have created the report files in the folder <client>/config/gateway, correct?
Same folders exists on server, like <server>/data/gateway and <server>/data/public_html/gateway.
The publishing is not much more then copy the files over and update the template link to the http adress.
Would you like to give a try?
Grusse Volker,
This is what I got from TS and it's ok now.
The templates used for the Gateway applications (in this case MS Word) can be both stored on the client and server side.
Based on the information that you have provided us with, you would like the users to use the server-side templates, for that, check out this article.
In this article you can find and determine which template is being used and from which location (client or server).
Many thanks!
A.
Hello Andranik,
great to hear that it works now for you.
Just to make you aware of the following:
1/ we have written a trigger to distribute the gateway xml files flexible to the right target directory. This is in particular helpful when you work with multiple stage systems.
2/ we have offered to some department admins the possibility to maintain the word templates by themselves. We use a template item type to upload (as attachment) and distribute the file into the correct target directory for testing or even prod.
So, in sum the Word Template development and deployment process is much simpler and shared among multiple persons.
If you are interested in some details, just send me a PN.
