In PTC Integrity/RV&S we have Testcase type having "Test Result" tab for showing the verdicts of Test execution performed under various Test Sessions.
How to export "Test Result" tab data from Testcase type into MS Excel, as one Test Session executed into multiple Test Sessions. Here how to export into MS excel ?
Newer versions of the software have alternatives that you could consider, see the snippet below -
Kartik
Kartik
Thanks for the reply, yes in RV&S 13 version its possible but I would be interested in 11.2 version
11.2 is a very old release and it may not have comparable functionality.
Regards
Kartik
Hi @Chittaranjan_11
Though 11.2 is very old version, still you can write report which gives you this data on web page and from where you can implement various export according to your need.
Vielen Dank / Many Thanks,
Kapil Jain
