I have to migrate from clearacase to MKS ( PTC ) with full revision history , could anyon eguide me about this ?
rcr
I have to migrate from clearcase to MKS ( PTC ) with full revision history , could anyone guide me about this ?
JoeBartlett
(To:rcr)
There are several members of the PTC Global Services team who have done migrations from ClearCase to Integrity so I would suggest reaching out to your PTC Salesperson to discuss options for that type of migration.
4 REPLIES 4
KaelLizak
(To:rcr)
Hello Ramya,
I don't know how to do this from ClearCase in particular, but the general process I would try to perform would be to create build sandboxes from the ClearCase data, and use those to create Source Integrity sandboxes to check in all non-ClearCase specific artifacts (in other words, your source control, but not any files ClearCase creates for metadata).
This gets trickier if you need to capture check points as well.
Generally, for these sorts of scenarios Global Services is called in to provide the expertise to perform these sorts of migrations.  I would recommend discussing this with your Account Manager.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
JoeBartlett
(To:rcr)
rcr
(To:rcr)
Hello ,
Is there any tool or script available to import data from any version control to MKS ( Integrity).
Ramya
KaelLizak
(To:rcr)
Hello Ramya,
In general, this goes back to Joe's answer:  the PTC Global Services team has tools for migrating data from many systems to PTC Integrity Lifecycle Manager (formerly MKS Integrity).
Kael
Kind Regards,
Kael Lizak
