Integration with Microsoft Visual Studio using different project name and directory name
ttran
when project name different from directory name where the project resides in, sharing with integrity create a new directory with the project name. When executing checkout from Integrity all files are checked out in the new directory. Is there a way to use different project name and directory name?
MichaelChatel
20-Turquoise
(To:ttran)
Hi Thien,
Some screenshots may help convey what you're asking, as I'm not sure exactly, what issue you are describing.  You may also want to open a Support case for this.
I suspect the behaviour you are seeing is probably by design, with the integration, but can you provide more info, to clarify?
