Is it possible to diff two dev paths in Integrity?
aworthdibello
I have not found a way to diff 2 separate dev paths in Integrity.
With other systems it is as simple as
diff <path1 at some tag> <path2 at some tag>
How is this done in Integrity?  How can you tell the differences in the content between dev paths?
Hello Amber,
The short answer is the si diff command, with two -r arguments, each with the checkpoint to compare.
Take a look at this thread, which basically covers the same thing:
Is there a CLI command that checks whether a member is merged to a given branch ?
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
1 REPLY 1
Hello Amber,
Kael
Kind Regards,
Kael Lizak
