I am using MKS Integrity Client 2009 SP6.
My question is if it is possible to have an archive copy from one project to another with:
1)all revisions including the branches (the number of the revision to be the same in both archives):
2) all labels
3) all revision description
Does the MKS tool offer this posibility for the Sorce part?
If yes, how is this done?
Thank you!
Hi Ioana,
this depends on your Integrity backend. If you have a RCS backend this is possible. With a databasebackend I think it is not possible.
If you have a RCS backend, just *copy* all the needed files in the archive folders on the server to the new destination, then use the import function in the client to get it into your project. Please note that this is not officially supported by Integrity and may cause severe problems in your project registry.
Heike
