Is there a way find out if the members on a devpath do not have the latest versions as their member revision ?
hmagnanao
trunk tips are not matching the member revision ???
kthierer
(To:hmagnanao)
If I had a sandbox pointing to that devpath my approach would be
   si print --filter=changed:newer
10 REPLIES 10
Hell Hector Magnanao‌,
This could be achieved by making "Restrict New Revision Available" to True in Policies for Configuration Manager Admin client.
I hope this is what intended?
hmagnanao
(To:skamaraj)
Hi Sathish,
I was looking more for a query or a CLI that would list out the files that has a new tip revision but not the member revision.
Hector
On a specific devpath.
kthierer
(To:hmagnanao)
hmagnanao
(To:kthierer)
this command works great !!! how would I display just the current member revision and the newest version on the tip ?
kthierer
(To:hmagnanao)
The following commands might be helpful templates for you
si print --recurse --revision=:memberbranchtip --filter=changed:newer --fields=memberrev,revision,membername,archivename --noHeaderFormat --noTrailerFormat
si print --recurse --revision=:trunktip --filter=changed:newer --fields=memberrev,revision,membername,archivename --noHeaderFormat --noTrailerFormat
Note that I have doubts how well these commands would compete for use cases like devpath of a devpath or manually
forced branches on checkin.
HTH Jürgen
hmagnanao
(To:kthierer)
Hi Jurgen,
I tried both queries above but I found a slight problem with them.  They only display the newer revisions only if they are in the same devpath.  They don't display the files that have a different version on a different devpath.  for example,  I have a devpath A and B.   I want to look at new versions on B and A respectively.  Is this possible to display ?
kthierer
(To:hmagnanao)
For handling 2 devpaths (not mainline and devpath) in this context I would prefer comparing complete project configurations
like following approach
c:\sandboxes\PRJ1_DP_A> si print -R  --revision=:member --fields=membername,revision,archivename --noHeaderFormat --noTrailerFormat > PRJ1_DP_A_conf.txt
c:\sandboxes\PRJ1_DP_B> si print -R  --revision=:member --fields=membername,revision,archivename --noHeaderFormat --noTrailerFormat > PRJ1_DP_B_conf.txt
...> si difffiles --gui c:\sandboxes\PRJ1_DP_B>PRJ1_DP_A_conf.txt c:\sandboxes\PRJ1_DP_B>PRJ1_DP_B_conf.txt
You might also use the output of si viewproject but I dont find this very diff friendly
hmagnanao
(To:kthierer)
Hi Klaus,
Is your command above comparing on 2 different devpaths ?  I'm trying to find the diffs on the same devpath.  How is this possible with your solution above ?  Please explain.
Hector
Klaus,
Thanks for your help.  Ignore my last question.  I think this is the correct command for me:
Thanks a lot,
Hector
