Is there a way to restore a document from its current contents to what it had at a specific time in the past? I know I can see it, but can I actually revert to it as the currently active version?
jclement
3-Newcomer
Is there a way to revert a document from its current contents back to what it had at a specific time in the past?  I know I can see it, but can I actually revert to it?
5 REPLIES 5
One option would be to export the old doc version as IIF and re-import the doc then as current. If the mapping is done correctly, all values should be restored incl. Traces etc.
Perhaps there are more options, but this just comes into my mind.
For IIF export and import you use the Gateway.
Regards
That should work, I should have thought of that.
Jeff
Jeff,
You may also want to vote on this Integrity product idea;
Restoring an item/document in Integrity Requiremen... - PTC Community
...to add your voice to it. Sounds like parts of what is being requested there, would also line up with what you want.
Hi Jeff Clement‌,
Another option is to branch the document as of that earlier time.  It would require you to update your references to point to the new 'branch', though.
Kael
Kind Regards,
Kael Lizak
Senior Technical Support Engineer
PTC Integrity Lifecycle Manager
Hi Kael,
That is our original plan, but we were hoping for something that didn't require having to redo the references.  We will probably go with that.
Jeff
