Issue with modifying Parameter Values after initially set
dschaaf
I have an issue with usage of Parameter Values.  When I enter a value for a specific item and then later go back to either modify the value or delete the parameter from the item, Integrity will not save the change and immediately reverts to the previous value when I refresh or select a different item.  Does anyone know why this is happening and how I might solve this issue?  The value is set within the item I have open and it is not a hierarchy issue.
0 REPLIES 0
