Issue with physical and logical files - MKS Implementer
MN_12056425
Hello Team,
I need help with MKS Implementer, PTC Inc.
The issue I have is with physical and logical files.
When I make changes to a file and promote it, the new objects do not have the same object authority as I had given manually.
So, every time I make changes to the object, I have to go to all the machines/environments and change the authorities.
1 REPLY 1
Hi @MN_12056425,
Thank you for your question.
Anurag
