Dear PTC-Community,
we have currently faced the problem with Mail-Trigger function implementation. We cannot find any proper solution on how to integrate the Mail-Trigger function into PTC.
Any advices would be much appreciated!
Best regards,
Daniel Remmers.
Hello Daniel,
there two steps to taken care of here to set email triggers:
Here is the article for more information:
Moreover, it needs more clear details of the issue to understand the cause.
Amit
Daniel,
Could you provide some more information, such as a use case.
Dan
Hello Daniel,
Amit
Thank you! The manual helped.
solution in short (out of my head):
Admin client node "Workflow & Documents" >> Triggers >> adapting js-file >> setting trigger rules
Admin client node "Configuration" >> mksis.mailserver >> entering the correct data of your companies mail server
uld You please share the steps to enable the smtp configuration with sendgrid?
We are getting error as "unauthenticates senders are not allowed"
tried as you mentioned.
When we tried to enable SMTP for ILM, its not working
1) Admin client -> enabled mail server
2)Admin client -> configured notifier mail address
3) created notification rule for my usre id and its not sending.. getting error as 'unauthenticated senders are not allowed"
Note: tested sendgrid functionality over command line from server with the same notifier user mail address.
We are using send grid and there is no option foungd in ILM to authenticate the send grid with username and password.. will be that the reason ?
can u share the contenct of the [page?
How to configure SMTP settings to get email notifications in Integrity lifecycle manager
I dont have an customer account to read this
