Does anyone have any experience with PTC MIIP and what other applications is it able to integrate with?
What is needed to get the PTC Integrity Integration Platform up and running?
Any information regarding MIIP besides whats available on the PTC site would be greatly appreciated.
We have out of the box adapters for several applications including ASAM, ClearCase, ClearQuest, DanTe, DOORS, EnterpriseArchitect, HPQC, Jira, Perforce, RIF, Rational System Architect, and Subversion.
You would need the IIP software itself, an IIP software license, and a separate database to be created for it (Oracle or Microsoft SQL Server).
For development, it is suggested to use Netbeans with the IIP SDK that is also offered on our PTC Software Downloads area. You would use the Netbeans NBM files to import the information for development you would want to use.
There is information that describes how to set this environment up. You can make your own adapter using the SDK if you wish. You would also need to have knowledge of BPEL to create sequences that use the adapters.
Hello Wesley,
do you know whether IIP and for example Integration ASAM is usually part of an Integrity Installation?
It is clear that it needs to be installed separately, but is it part of the general License agreement ?
Have a nice day,
Klaus
Hi Klaus,
IIP is a separate license-able product that needs to be purchased in addition to Integrity.
Wes
