I would like to add a suggestion for new Modeler releases.
When using big matrices and scrolling down/to the side, the first row/column of the matrix cannot be seen anymore.
It would be great to have a fixed first line/column in the matrices, so that it is always possible to see the names of the elements
David
You can bring your idea here: https://community.ptc.com/t5/Windchill-Systems-Software/idb-p/IntegrityIdeas
Thanks, I added it to the other forum.
You're welcome.
