Hello team!
Would like to get your thoughts about possible limitations of using Document Versions?
I remember after I have created a Doc version I was not able to edit this doc any longer. Was this me or this is a proper system behavior?
Andranik
Am I right saying that ReqDoc versions are for reference (for comparing) only and cannot be edited any longer?
Active is the latest version only.
This is pretty different from Windchill PDM approach.
Windchill PDM of course has configuration management features to handle all this things.
Regards
From "Help Center" - "Limitations For Document Versioning": https://support.ptc.com/help/windchillrvs/r12.3.1.0/en/index.html#page/IntegrityHelp/version_limitations.html
Hi Vladimir,
Thanks for an answer,
In my case I was not able to work with revisioned documents any longer.
And I don't know why. All commands are greyed out - so nothing can be done with these documents.
Regards
Regards
