Result Editor: changing the Annotation field property
Zeiad-Alkassem
In the Result Editor,when the test session test is completed, How i can change the "Annotation" field property to be selectable or copy its value.
Is there any way to change it?
Version : 10.8
Regards
Zeiad Alkassem
4 REPLIES 4
I suspect it's not currently possible Zeiad.
(I'm surprised I don't find an existing knowledge article or SPR for this, as I imagine someone must have brought this up in the past).
Not directly related, but this knowledge article,
https://www.ptc.com/en/support/article/CS251362
Seems to have similar problem, in that if it contains an URL, you also can't click on it, or interact with the annotation field.
You may want to open an Integrity (Windchill RV&S) Support case, to see what Support can find.
Ahh, I knew there must have been some past mention of this:
Much older article:
https://www.ptc.com/en/support/article/CS161445
So doesn't seem possible, due to how it was designed.
Hello @MichaelChatel ,
Thank you for your reply ..
I think sometimes we need to copy the text for another using , anyway If there are Interest, i will open a new case for it.
Regards
Zeiad
Much older article:
Thank you for the information and advice!
