Context : Integrity provides us standard reports like "Document Content". I'm interested by this report, because it is user friendly : clear, displayed section in order to show all level of requirement and titles, etc...
Expected : to have a compliance matrix. I have create 2 field : "Compliance Status", a pick List field, and "Compliance Comments" (a text field). It's an official document that we need to transmit to our client, or internal services...
I want to do a copy of "Document Content" report in order to create a new report with the same format but with additional fields:
- 2 fields : "Compliance Status" and "Compliance Comments"
- "ID" or "Item ID (Web Link)"
- "Category".
Question : The problem is that this copy of standard report is not modifiable for the content. Impossible to add new fields in the display of the report... I can copy this report but not modify it in order to display additional field.
There is no solution for a customization of this copy of report ?
Thanks for your reply !
Eudes
Hello Volker,
I'm not sure to understand you when you said "make needed changes right in the file itself."
In fact, I have administrator rights. So I have already copy report template file in Integrity Administration (Administration->Workflows and Documents->Reports->Copy Admin Report), and choose different parameters. It's your report template file ?
In this copy, I have not the choice of "Item field" like other report. So I can't to choose display field.
Eudes
Hello Eudes,
Integrity Reporting is file based.
The files are in <server>\data\reports\recipes
The registration is therefore only one part. The file itself is the second.
Regards, Volker
Hello Volker,
thanks a lot for this information, I see all the architecture of each report in this folder.
Normally, I can now find a way to customize standard reports!
Best regards,
Eudes
Hi @edegeis,
Greetings from my side.
I can help you regarding your query "How to edit Report as per your requirement" and can tell you some extra functionality that i added in this report to make my own like export feature, Dynamic Trace Feature etc.
If you need help you can mail me at "Kapil.Jain@itcinfotech.com".
Kapil
