[SI] readonly DevPaths?
JensN.
Hi @all,
is it possible to set a complete Branch (DevPath) in source to readonly, and the parent is still writable?
Thanks, Jens
mrump
(To:JensN.)
Hi Jens,
that's easy.
You just need to create a specific ACL for the Dev Path and deny the
  • checkin,
  • modify member revision
  • add member,
  • drop member,
  • add subproject,
  • drop subproject,
  • and configure subproject
permissions for the everyone groups
HTH Matthias
Note: Keep in mind that you ensure the ACL for the Dev Path is not inherited from the mainline.
mrump
(To:JensN.)
Hi Jens,
that's easy.
  • checkin,
  • add member,
  • drop member,
  • add subproject,
  • drop subproject,
HTH Matthias
JensN.
(To:mrump)
Hi Matthias,
thanks again
kind regards, Jens
