Hi @all,
is it possible to set a complete Branch (DevPath) in source to readonly, and the parent is still writable?
Thanks, Jens
Hi Jens,
that's easy.
You just need to create a specific ACL for the Dev Path and deny the
permissions for the everyone groups
HTH Matthias
Note: Keep in mind that you ensure the ACL for the Dev Path is not inherited from the mainline.
Hi Jens,
that's easy.
HTH Matthias
Hi Matthias,
thanks again ![]()
kind regards, Jens
