State does not change if a shared requirement changes
odiop-2
9-Granite
Hello all,
Could someone help
- one shared a requirement of document 1 in document 2.
-        One reviewed the requirement in the document of 2 and sets the state to released or review.
-        If one changes the requirement in the document 1, then the requirement in the document 2 changes automatically.
-        The state in the document 2 remains on released or in review.
-        Since the text changed we would like to have the state in the document 2 to jump back to in progress like in the document 1. Otherwise the developer will not be aware of the      changes in document 1
Is there a way to implement it without using email notification?
Oumar
1 REPLY 1
Hallo Oumar,
  the trigger fires on the item in which you are. Not on the second item (shared).
  Because states are item individual, you need a more complex trigger to handle this situation correctly.
  The trigger must look into ALL related (branched) items and check one by one, and update the state accordingly.
  It must be a script based trigger.
Regards
