Hello
We are using Integrity 10.8.0.8356
I noticed that in the web interface the times are displayed differently than in the desktop client by 1 hour.
In the GUI client I see this item information
integrity://server:port/im/viewissue?selection=134804
OpenIssue: 134804
Created by:..... on May 31, 2016 10:26:03 AM
Modified by:.....on May 31, 2016 10:26:23 AM
In the web interface(in any browser) I see this item information
http://server:port/im/issues?selection=134804
OpenIssue: 134804
Created by:..... on May 31, 2016 11:26:03 AM
Modified by:.....on May 31, 2016 11:26:23 AM
Is there any setting in the web application interface, because I suspect that it behaves differently than the Java GUI client ?
This is not a browser issue, all display the same values, it is rather a matter of the web application interface behavior.
Thanks!
Hi Alexandru,
You may want to open a Support case to explore this, but I'm guessing you probably have the Integrity server in a different time-zone (off by 1 hour), then the location where the GUI client is being used?
The GUI client will always convert and show time local to the user's location/machine, whereas, the WebUI uses the server's timezone info.
Indeed, the Integrity server is in another country and a difference of 1 hour exists between us ![]()
Still my intuition says that the web application interface should display the same datetime values as the GUI interface,
because we are speaking about item creation or item modification datetimes.
